System requirements: Database server
Feature |
Database server requirement |
Operating system |
Operating system and hardware as specified by the Oracle 12c database software. Supported Windows platforms:
Database |
Oracle Database Server 19.7, with or without Oracle Real Application Clusters (RAC) Note: You must register the .NET assemblies to the Global Assembly Cache (GAC) after the initial installation, and each time you apply a patch. For more information, see the Installation Guide. Mandatory database components:
Processor |
Four or more 3.3 GHz Intel Xeon class or higher processor cores |
Memory |
4 CPU, 24 GB RAM or more |
Disk space |
In addition to the space required for the Oracle database software installation:
Connectivity |
100/1000 NIC |
Display |
No requirements |
CD drive |
Required only if you need a CD drive to install Oracle Server |
