Setting up a keyboard to use different locales
When the Windows operating system starts in a specific locale, it updates the keyboard settings for that locale. If you will develop a study in a language other than the locale in which you are located, use this procedure to switch your keyboard settings and shortcuts between locales.
In each locale, set up the Windows operating system to support multiple text input languages—the local language and the language in which the study is developed:
- Select Control Panel > Regional and Language Options > Languages tab > Details.
- In the Settings tab of the Text Services and Input Languages dialog box, make sure that both the local language and the study development language are included in the list of supported text input languages.
- Activate the Language Bar.
- Use the Language Bar to switch between the local language and the study development language. Always log on to the Central Designer application in the study development language.
