Additional locale settings
You set the default locale for a study in the Central Designer application.
The Microsoft Windows operating system also provides the following language-related options.
Operating system language-related options
Option location |
Purpose |
Control Panel > |
Controls the formatting conventions for numeric data, including dates, times, numbers, and currencies. Note: If you do not set the default locale for a study in the Central Designer application, this setting is used as the default locale for a study. If you modify the regional setting, you must close and reopen the Central Designer application to use the new locale. |
Control Panel > |
Controls the language of text in menus and dialog boxes. The option appears only if you have one or more Multiple User Interface (MUI) packs installed. The Central Designer user interface supports only English. |
Control Panel > |
Controls the language that you use to type information on the computer. For example, if the default locale for a study is set to French (France), all study metadata is saved as French metadata. Even if the input language is English (United States) and you type information in the English language, the information is saved as information entered for the French locale. |
