Codelist properties
Properties common to all study objects
All study objects have the following properties.
Property
Description
Description
Description of the study object. The description can have 0-255 characters.
Identifier
Unique internal identifier of the study object.
Locked
When True, the study object is locked.
Modified
When True, the study object has not been saved since the last modification.
New
When True, the study object has not been saved yet. When False, the study object has been saved at least one time.
Protected
When true, the study object is protected. When a study object is protected, you cannot :
- Update or lock it.
- Add child study objects to it by pasting or dragging and dropping.
- Delete its child study objects.
RefName
RefName of the study object. The RefName can have 1-63 characters.
Revision
Revision number of the study object.
Title
Title of the study object. The title can have 1-63 characters.
Version
Version number of the study object. The version number is incremented only when a user explicitly updates it.
Codelist properties
Property
Description
CodeListType
Type of codelist; integer, float, or text.
