Codelist item properties
Properties common to all study objects
All study objects have the following properties.
Property
Description
Description
Description of the study object. The description can have 0-255 characters.
Identifier
Unique internal identifier of the study object.
Locked
When True, the study object is locked.
Modified
When True, the study object has not been saved since the last modification.
New
When True, the study object has not been saved yet. When False, the study object has been saved at least one time.
Protected
When true, the study object is protected. When a study object is protected, you cannot :
- Update or lock it.
- Add child study objects to it by pasting or dragging and dropping.
- Delete its child study objects.
RefName
RefName of the study object. The RefName can have 1-63 characters.
Revision
Revision number of the study object.
Title
Title of the study object. The title can have 1-63 characters.
Version
Version number of the study object. The version number is incremented only when a user explicitly updates it.
Property
Description
InForm properties
Study Completion Status Items
Codelist items in the codelist for the Completion Status item on the Study Completion form, which is used in reporting in the InForm application to determine whether a subject dropped out of a study. Options include:
- None—(default) The codelist item is not part of the codelist for the Completion Status item.
- Complete Study (Study Completion)—Indicates that the subject has completed the study.
- Incomplete Study (Study Completion)—Indicates that the subject has not completed the study.
Standard properties
Code
Code of the codelist item.
CodeListType
Type of codelist; integer, float, or text. The value of this property is populated with the value for the CodeListType property of the codelist parent of the codelist item.
READ-ONLY
Label
Label of the codelist item.
