Date-Time Data Point dialog box—Option descriptions
Use the Date-Time Data Point dialog box to specify custom mappings for date time items. The dialog box appears when you map a date to a data series that has a type of Integer or Text or when you modify the date part of a mapped date time item.
Note: When you map a date time item to an integer data series in a CDD mapping, the item is mapped as a split date, with a separate column for each date time part.
Option |
Description |
All in one column |
Map the date to a single database column. This option is available only if the date item is mapped to a data series with a type of Text. |
Split columns |
Split the date parts into multiple database columns. If the mapping is for:
CIS Date Part |
Date part to map. This option is available for rule and CIS mappings but not for CDD mappings. |
