Item has units dialog box—Option descriptions
Option |
Description |
Normalized Value |
Map the normalized value of the item with the data series. Normalization is the process of converting data to a required format. The normalized units appear in parentheses. |
Entered Value |
Map the entered value of the item with the data series. The entered value can be the same as or different from the normalized value. |
Entered Unit |
Map the unit in which a value is entered. |
