Mapping Editor—Field descriptions
Field |
Description |
Grid section |
Title |
Name of the data set. |
Description |
Description of the data set. |
Alias |
Alias for the data set. If an alias is present, it is used as the CDD table name in CDD mappings and as the Clintrial panel name in CIS mappings. If an alias is not present, the RefName is used as the column header. Because RefNames must be unique throughout a study, you must create an alias if the RefName is used by another study object. Data set aliases must be unique within a mapping. Note: Checking for RefName and alias uniqueness is case insensitive; for example, the names BP and bp are considered identical. |
Standard Dimensions section |
In this section, you view the standard data dimensions that were selected when the data set was created. |
Study |
RefName of the study. |
Subject |
Subject ID. |
Section |
RefName of the section. |
Section Index |
Instance of a repeating section. |
Event |
RefName of the study event. |
Event Index |
Instance of a repeating study event. |
Form |
RefName of the form. |
Form Index |
Instance of a repeating form. |
Item |
RefName of the item. |
Custom Dimensions section |
In this section, you view the custom data dimensions, if any, for the data set. |
Name |
Name of the custom dimension for the selected data set. |
Description |
Description of the custom dimension created with the selected data set. |
Data Type |
Data type of the custom dimension created with the selected data set. The following types are available:
Codelist Lookup |
Click the button to choose or create a codelist to use for the custom data dimension labels. |
Note: The Standard Dimensions and Custom Dimensions sections are read-only.
