Select Custom Dimension dialog box—Option descriptions
The Select Custom Dimension dialog box appears when you add an item to a data series, and the item is in a data series that is in a data set with one or more custom data dimensions defined.
Option |
Description |
X |
When checkbox is selected, custom data dimension is selected. |
Dimension Name, Dimension Description |
Name and description of the custom data dimension. |
Data Type |
Data type of the custom data dimension |
Labels |
Drop-down list containing the codelist item labels for the custom data dimension. Note: If you type a label or modify an existing label, a new codelist item is created for the codelist. |
