History Viewer dialog box—Option descriptions
Option descriptions for the History Viewer dialog box
Field |
Description |
Top section |
Object |
Name of the study object. |
Unlocked or Locked icon |
Indicates whether study object is locked or unlocked. |
Object [name of study object] section |
Revision/Version |
Revision or version number of the study object, with either Version or Revision in parentheses to indicate if it is a version or revision. Note: This value is for the selected study object only, not for the study in which the study object exists. This value may differ from the value that appears for the Revision property at the bottom of the History Viewer dialog box. |
Label |
Altered By |
Name of the user who modified the study object for the version or revision. |
Date |
Day and time when the study object was modified for the version or revision. |
Description |
View changing radio buttons |
View Versions |
All versions of the selected study object appear in the top grid. |
View Every Edit |
All revisions of the study object appear in the top grid. |
Buttons |
Differences |
(Enabled when you select two versions or revisions.) View the differences between two versions or revisions of a study object. |
Revert to |
Revert to a previous version or revision of a study object. |
