Import Wizard options - CSML or ODM file
Pages in the import wizard for CSML or ODM files
Page |
Option |
Description |
Welcome |
Introduction page. |
Import Type |
Select the source of the data to import. |
Import CSML or ODM file |
Generate study objects from a file in CSML or ODM format. |
Harvest InForm Resources |
Generate study objects from the components of an InForm study. |
File Location |
Path of file to import |
Specify the path of the CSML or ODM import file, or click Browse to locate the import file. |
Study Administration Import Mode |
This page appears only for the CSML import type, if the CSML file contains study administration objects. |
Import study objects and administration data. |
Import both study objects and study administration objects. |
Import administration data only. |
Import only study administration objects. |
Import study objects only. |
Import only study objects. |
Rule Import Mode |
Rule Import Mode |
Only the Import as Collaboration Notes option is supported. With this option, each imported rule is converted to a collaboration note in the Central Designer application. Note: This option applies only if the Import Type is ODM; if the Import Type is CSML, the import process creates a Central Designer rule for each imported rule. |
IPR Import Mode |
Import IPR data |
Select whether to import in-place revision objects. Note: This page appears only if the file contains in-place revision objects. |
Ready to Import Data to Central Designer |
View a summary of the import options selected in the wizard. |
