Run tab of the Rule Test Cases dialog box—Option descriptions
In the Run tab, you run validate rules, run test cases, and view the results.
Run tab of the Rules Test Cases dialog box—Option descriptions
Field |
Description |
Top section |
Check Syntax |
Check syntax for the selected rules. |
Execute Tests |
Run the selected test cases and check syntax for the selected rules. |
Stop |
Stop the action. |
Go to Rule |
You are brought to the following location:
Progress indicator |
If the action is successful, the indicator is green. If one or more rules or test cases is invalid, the indicator is red. |
Passed |
Metrics for the test cases that you ran. Note: If the IgnoreTest property for a test case (set in the Test Properties tab) is set to True, the test case is skipped. |
Grid |
Status |
Object Name |
Study object on which the rule was created. |
Rule Name |
Name of the rule. |
Validation |
Indicates whether the rule is valid, invalid, or incomplete (for rules or global conditions that have valid syntax but are not complete; for example, if the rule has no action defined). |
Test Name |
Results |
Expected |
Actual |
Time |
Execution Results section |
Select a result in the grid to view additional information. |
