Rules tab—Option descriptions
Option |
Description |
Toolbar buttons |
New Rule |
Create, edit, or delete a data-entry rule. |
Check Syntax |
Check the syntax of a rule. |
Cut |
Cut, copy, or paste a data-entry rule. |
Enable |
Enable all disabled rules or disable all enabled rules for a study object. To enable or disable only parent rules for a study object, deselect the Show Child Rules checkbox before clicking the button. |
Show Errors/Hide Errors |
View the errors associated with the rule. You must check syntax before you can view errors. |
Rule Tests |
Open the Rule Test Cases dialog box and create rule test cases. |
Top section |
Show Child Rules checkbox |
When selected, all data-entry rules on the selected study object and its children appear in the grid. |
Summary grid |
Description |
Description of the rule. |
Expression |
Expression of the rule. |
Id |
Identification information for the rule. |
Lock icon |
Appears if the rule is locked. |
Parameters |
Parameters for the rule template. |
Parent |
Title of the study object to which the rule is attached. |
Parent RefName |
RefName of the study object to which the rule is attached. |
Parent Type |
Type of study object (such as a form) to which the rule is attached. |
RefName |
RefName of the rule. |
Syntax icon |
Indicates the validity of the rule syntax.
Target |
Target application to which the rule is deployed. |
When |
Event that triggers the rule (you select this option from the Evaluate on Event drop-down list in the Rule Wizard). |
Rule Summary section |
A structured specification of the rule appears, with links that open the Rule Wizard. |
