InForm Items Editor—Option descriptions
Columns common to all study object editors
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view.
Option |
Description |
Data Label |
Text label for the item, enabling access to the item in a target table with the Patient To Control key type or any of the pivot key types. |
Display Override |
Determines the default behavior of an item when a layout is generated.
This is a custom property for items deployed in a study in the InForm application. |
Item Required |
True (default) or False, indicating whether the item is required for data entry on the form to be complete. This is a custom property for items deployed in a study in the InForm application. |
MaxProperty |
If a MaxValue is specified for the item, indicates whether the value can be less than or less than or equal to the MaxValue. |
MaxValue |
Maximum value that the InForm application will allow to be typed for the item. |
MinProperty |
If a MinValue is specified for the item, indicates whether the value can be greater than or greater than or equal to the MinValue. |
MinValue |
Minimum value that the InForm application will allow to be typed for the item. |
PHI |
True or False (default), indicating whether an InForm user might enter Personal/Protected Health Information (PHI) for the item. |
Question |
Default question for the item. This question appears on the form if no customized label or translation is defined for the item. The question can have 0-1000 characters. Certain words may be reserved for this field. |
SDV Critical |
True or False (default), indicating whether the item is considered critical for source verification. If you select True, SDV Required changes to True. |
SDV Required |
True (default) or False, indicating whether the item requires source document verification. This is a custom property for items deployed in a study in the InForm application. |
ShortQuestion |
Text of a short version of the item question. In the InForm application, the short question appears as a column heading in a repeating form, an itemset, and in reports generated by the Reporting and Analysis application. The short question can have 0-255 characters. Certain words may be reserved for this field. |
Special Fields |
Type of special InForm field, or None, indicating that the item is not a special InForm field. Available special fields, along with the forms in which they appear, are:
Type |
Item type; one of the following, or a custom item type defined in a library to which the study has access:
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
