General tab of the Form Editor or Section Editor—Option descriptions
Option |
Description |
Settings section |
Title |
Title of the form or section. The title can have 1-63 characters. |
Short Title (Form Editor only) |
Short title of the form. The short title is deployed to the InForm application as the form mnemonic. The short title can have 1-63 characters. |
RefName |
RefName of the form or section. The RefName can have 1-63 characters. |
Description |
Description of the form or section. The description can have 0-255 characters. |
Behavior section |
Repeating |
Indicates that the form or section is repeating. Multiple instances of the same set of data appear in the form or section. |
Common (Form Editor only) |
Indicates that the form is common. The same data is visible in all study events that contain the form. |
Short Title Languages section (Form Editor only) |
Language |
Language and locale to which the short title is translated. |
Short Title |
Translated text of the short title. The short title can have 1-63 characters. |
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
