Item properties
Properties common to all study objects
Item properties
Property |
Description |
CDD properties |
Data Label |
Text label for the item, enabling access to the item in a target table with the Patient To Control key type or any of the pivot key types. |
Component Settings |
(The following settings are used only for date time items.) |
DayAllow, |
When True, indicates that the date time item includes a control for the component of the date time. |
DayAllowUnknown, |
When True, indicates that the date time item includes a control for the component of the date time and allows a user to mark the value unknown. |
DayRequired, |
When true, indicates that the component of the date time item is required. |
InForm properties |
Collapsible |
True or False (default), indicating whether the item is always visible on the form in the InForm application, or is collapsed and not visible until a condition is met. |
Display Override |
Determines the default behavior of an item when a layout is generated.
Item Required |
True (default) or False, indicating whether the item is required for data entry on the form to be complete. |
MaxProperty |
If a MaxValue is specified for the item, indicates whether the value can be less than or less than or equal to the MaxValue. |
MaxValue |
Maximum value that the InForm application will allow to be typed for the item. |
MinProperty |
If a MinValue is specified for the item, indicates whether the value can be greater than or greater than or equal to the MinValue. |
MinValue |
Minimum value that the InForm application will allow to be typed for the item. |
PHI |
True or False (default), indicating whether an InForm user might enter Personal/Protected Health Information (PHI) for the item. If you select True:
SDV Critical |
True or False (default), indicating whether the item is considered critical for source verification. If you select True, SDV Required changes to True. Note: The SDV Critical setting for an item can be overridden in the InForm application. |
SDV Required |
True (default) or False, indicating whether the item requires source document verification. |
Special Fields |
Fields used on the special forms for the InForm application.
Standard properties |
Question |
Question for the item. The question can have 0-1000 characters. |
ShortQuestion |
Short question for the item. The short question can have 0-255 characters. |
Miscellaneous properties |
Change assigned codelist |
Available only in libraries. True or False (default), allow users to choose a different codelist for the item in a study. If set to True, Change assigned subset is also set to True. |
Change assigned subset |
Available only in libraries. True or False (default), allow users to choose a different codelist subset for the item in a study. If set to False, Change assigned codelist is also set to False. |
