Previous Topic
Next Topic
Book Contents
Form and section properties
Properties common to all study objects
Form properties
Property
Description
CIS properties
Page Key Value
Value of the Clintrial page key, used for transferring data to the Clintrial application through CIS mappings. If you specify the Page Key Value, it overrides the form RefName as the page key.
InForm properties
Item Required
True (default) or False, indicating whether the item is required.
SDV Required
True (default) or False, indicating whether the item requires source document verification.
SDV Critical
True or False (default), indicating whether the item is considered critical for source verification. If you select True, SDV Required changes to True.
Special Forms
Type of special InForm field, or None, indicating that the item is not a special InForm field. Available special fields, along with the forms in which they appear, are:
  • Initials (Screening).
  • DOB (Screening).
  • Screening date (Screening).
  • Patient No. (Enrollment).
  • Initials (Patient Identification.
  • Completion status (Study Completion).
  • Drop-out reason (Study Completion).
  • DOV (Date of Visit).
  • Randomization field (Randomization).
Standard properties
AssociatedForm
Indicates whether the form is an associated form.
  • None—Form is not an associated form.
  • [Form name]—Name of the form with which the form is associated.
Common
When True, the form is a common form.
Tip Tip: Do not change this setting for a form that was already deployed. Instead, to avoid potential negative downstream impact, create a new form with the updated setting.
Fixed
For sections only. When True (used for repeating sections), the section contains items that are deployed as a Repeating Data itemset.
Repeating
When True, the study object is repeating.
Short Title
Short title of the form, used as a mnemonic when deployed.
Send Feedback
