Coding tab—Option descriptions
Note: This tab appears only after you have defined context information for a coding map and when the coding map is selected in the top panel. Not all dictionaries allow you to define context information.
Field |
Description |
Top panel |
Assign queries to Item |
Title of the item to which to assign queries for the verbatim in the InForm application. |
Assign queries to Question |
(Optional.) Question associated with the item to which to assign queries for the verbatim in the InForm application. |
Assign queries to RefName |
(Optional). RefName of the item to which to assign queries for the verbatim in the InForm application. |
Coding Map RefName |
RefName of the coding map. |
Dictionary Type |
Name of the dictionary type for which the coding map is created. |
Form Name |
Form on which the verbatim item exists. |
Verbatim Item |
Title of the verbatim item for which a coding map is created. |
Verbatim Type |
Verbatim type that was specified for the coding map. |
Verbatim Question |
Default question of the verbatim item. |
Verbatim RefName |
RefName of the item. |
Bottom panel—Coding Results tab |
Dictionary Level |
Dictionary level for which the coding map is defined. |
Level Type |
Information that indicates whether the target item is for:
Target Item |
Title of the item that is specified for the dictionary level in the coding map. |
Target Question |
Default question of the item that is specified for the dictionary level in the coding map. |
Target RefName |
RefName of the target item. |
Bottom panel—Context Information tab |
Context Meaning |
Descriptive text for the context information. This information is displayed exactly as it is defined in the dictionary. |
Context Item |
Title of the context item. |
Context Question |
Default question of the context item. |
Context RefName |
RefName of the context item. |
