Coding Map dialog boxes—Option descriptions
Option |
Description |
Dictionary type |
List of all dictionary types (including custom dictionary types, if any) that have been installed, enabled, and selected for the given study or library. For more information, see:
After you select a dictionary type, additional fields in the dialog box (including Verbatim Type and the information in the grids) are populated with data from the dictionary. |
Item to code |
List of titles for all text items that can be coded. Note:
Verbatim type |
List of verbatim types that are enabled for the selected dictionary type. The field is enabled after you select a dictionary type. |
Assign queries to |
List of items that are eligible for query assignment, including the verbatim item. Each item in the list is:
Coding Results tab |
Dictionary Level |
Dictionary level for which the coding map is defined. |
Level Type |
Information that indicates whether the target item is for:
Target Item |
List of titles for all text items that can be selected as target items for a dictionary level in the coding map. If you select an item, the Target Question field is populated with its question. The list does not contain items that are already a verbatim, text item, or context item for the specified dictionary type, unless you are modifying a coding map. In that situation, the list includes the item that is currently assigned to the row, so you can review the list of options and reselect the item if you decide not to change the assignment. |
Target Question |
List of default questions for all text items that can be selected as target items for a dictionary level in the coding map. If you select a question, the Target Item field is populated with the item name. |
Context Information tab |
Context Meaning |
Descriptive text for the context information. This information is displayed exactly as it is defined in the dictionary. |
Context Item |
List of titles for all text items that can be selected as context items for a dictionary level in the coding map. If you select an item, the Context Question field is populated with its question. The list does not contain items that are already a verbatim, text item, or context item for the specified dictionary type, unless you are modifying a coding map. In that situation, the list includes the item that is currently assigned to the row, so you can review the list of options and reselect the item if you decide not to change the assignment. |
Context Question |
List of default questions for all text items that can be selected as context items for a dictionary level in the coding map. If you select a question, the Target Item field is populated with the item name. |
