Query Action dialog box—Option descriptions
Option |
Description |
Initial Query State |
Initial state of the query.
Item |
Item on which the query will be issued. You can:
Locale |
Locale of the query message. Note: To translate information, you must have the necessary language skills defined in the Central Designer Administrator application. |
Message |
Query message that appears. The query message must be 255 characters or fewer. The following errors occur for query messages that have 256 characters or more:
Note: A parameterized string in an email message or query that is generated in the InForm application follows the formatting that is specified for the site in the InForm application. Not allowed and unknown components of a date time value appear as asterisks (*). Leading and following underscores in the value are removed automatically. |
Message Parameters |
Optional parameters that you can create and use in the query message. Type a value or drag information from the Data, Functions, Constants, and Globals tabs. |
Reference tabs—Available components |
List of the components that are available for use in the rule being defined. By default, these tabs appear on the right side of the dialog box. When you select a tab, the Reference section appears, with tabs along the bottom edge. |
Data tab |
The available study objects appear in a tree structure similar to the Project Explorer. |
Functions tab |
The available functions appear in a tree structure organized by class. Note: Functions are defined in the Study Editor or Library Editor. |
Constants tab |
The available constants appear in a tree structure organized by class. Note: Constants are defined in the Study Editor or Library Editor. |
Data Mappings tab |
The components of the available mappings appear in a tree structure similar to the Project Explorer. |
Show All checkbox |
When selected, all available study objects as well as their properties appear. When not selected, only the available study objects appear. |
