Invoke Function dialog box—Option descriptions
Use the Invoke Function dialog box to assign values to the parameters named in a function that you are invoking in a rule or global condition definition.
Option |
Description |
Function |
Name and description of the function being invoked. |
Return Type |
Data type of the value returned by the function. |
Reference tabs—Available components |
List of the components that are available for use in the rule being defined. By default, these tabs appear on the right side of the dialog box. When you select a tab, the Reference section appears, with tabs along the bottom edge. |
Data tab |
The available study objects appear in a tree structure similar to the Project Explorer. |
Functions tab |
The available functions appear in a tree structure organized by class. Note: Functions are defined in the Study Editor or Library Editor. |
Constants tab |
The available constants appear in a tree structure organized by class. Note: Constants are defined in the Study Editor or Library Editor. |
Data Mappings tab |
The components of the available mappings appear in a tree structure similar to the Project Explorer. |
Show All checkbox |
When selected, all available study objects as well as their properties appear. When not selected, only the available study objects appear. |
Parameter description section |
Lists the parameters that have been defined for the function, along with spaces in which to specify their values in the rule or global condition expression. |
Parameter |
Name of the parameter. |
Data Type |
Data type of the parameter. |
Value |
Value the parameter takes in the rule or global condition expression:
