Mark a custom event change as an in-place revision
- At the bottom of the Project Explorer, click the Study Information (
) button. - In the Project Explorer in the InForm folder, select Custom Events, then select a custom event.
- At the top of the Layout tab, all the way to the right, click IPR Configuration.
- On the IPR Configuration screen, type a description of the change you made to the custom event (optional).
- Select or add the deployment instance where you want to deploy the in-place revision.
- Optionally, to compare the new custom event with the same custom event from an existing InForm study version, select the existing study version, and click View Differences. For more information, see View the differences between two versions of a custom event.
- Click Close.
- Next, contact the person who does study validation at your organization to validate and deploy the study.
