View the differences between two versions of a custom event
- If you manually deploy your study, you must have a successfully deployed baseline to view the differences between two versions of a form.
- If you perform an in-place revision and manually deploy the study, when you attempt to view the differences between two versions of a form, the differences shown are not correct.
- At the bottom of the Project Explorer, click the Forms and Transactions (
) button, and expand the InForm folder and the Forms folder, if necessary. - Select a form and select the Layout tab.
- At the top of the Layout tab, all the way to the right, click IPR Configuration.
- Select a deployment instance and a study version, and click View Differences.
