Edit and translate a question for a locale
- At the bottom of the Project Explorer, click the Forms and Transactions (
) button. - In the Project Explorer, select a form or item, and select the Layout tab.
- At the top of the Layout tab, select the Locale, then select a locale for which you want to edit or translate text.
- Right-click a question, then select Edit Question.
- Type the question text, then press Enter.
