Edit and translate a codelist item label override
You can override the label for a codelist item in a layout.
- At the bottom of the Project Explorer, click the Forms and Transactions (
) button. - In the Project Explorer, select a form or item, and select the Layout tab.
- Right-click the control for codelist items, and select Edit Label Override.
- From the Codelist item drop-down list, select a codelist item.
- In the Label override field, type the new label for the codelist item.
- Click OK.
Note: When you override a codelist item label for a codelist that is shared across multiple objects and uses the Study Completion Status Items property, sometimes InForm displays the codelist item label incorrectly. Instead of overriding the codelist item label, you can create a separate codelist with codelist items containing the labels that you need.
