How can I switch between locales and provide translations?
Every layout supports all locales. You do not need to create a unique layout for every form and locale in the study. Use the Locales drop-down list on the toolbar in the Layout tab to switch between locales and provide translations.
Translations are not layout-specific. Every layout supports every locale that is supported by the study. For example, if you have two layouts, you can view the translations for every supported locale in each layout.
You can provide translations for the following components in a layout:
- Captions.
- Section notes.
- Form and section titles.
- Questions.
- Codelist item label overrides.
Note: You can also provide translations for questions in the Design tab of the Item Editor.
You can translate codelist item labels in the Codelist Editor.
