In this section What data does the integration require? Why would I make the Safety Case form dynamic? When might an InForm site user include multiple adverse events when sending data to Argus? How can I use a dynamic grid section on a form? When will an InForm site user use a Safety Case form? How do I include the unit of measurement with items I create in Central Designer? What's in the data sets used to process data transmissions? What is the syntax of the _SavetoDB function? How does a calculation rule work? Are there rules that are not supported for items in the dynamic grid? What happens in InForm when a source form with a dynamic grid is deleted? What kind of queries should I include on a dynamic grid item? What is data mapping? Are there fields that I don't need to map? When and how are data mappings validated? Which items have data series for transmitting coded or verbatim data? What alias names should I use when creating custom data series? How do I trigger InForm Publisher to send adverse event data to Argus based on an onset date? |
