What alias names should I use when creating custom data series?
These are the alias names to use when creating custom data series.
Alias names in custom data series
Data Set Title |
Tab in Argus Safety |
Alias Naming Convention |
Safety_Case |
General |
String fields: Cust_General_Str_<1...12> Number fields: Cust_General_Num_<1...12> Date fields: Cust_General_Dt_<1...12> |
Subject |
Patient |
String fields: Cust_Patient_Str_<1...12> Number fields: Cust_Patient_Num_<1...12> Date fields: Cust_Patient_Dt_<1...12> |
Subject_AdverseEvent |
Event |
String fields: Cust_Reaction_Str_<1...12> Number fields: Cust_Reaction_Num_<1...12> Date fields: Cust_Reaction_Dt_<1...12> |
Example
In the sample studies delivered with the InForm and Argus Safety integration package, the Subject_AdverseEvent data set has a custom data series with the following properties:
- RefName - DSRReaction_Cust_float_1
- Title - AE_Cust_float_1
- Alias - Cust_Reaction_Num_1
This mapping means that in the Event tab of Argus Safety, the user-defined float field 1 receives data from the InForm item mapped to the AE_Cust_ float_1 data series.
