How do I trigger InForm Publisher to send adverse event data to Argus based on an onset date?
InForm Publisher watches for and collects serious adverse events to send to Argus Safety.
The before and after onset dates for an adverse event can be used to associate the adverse event with related safety data based on date ranges you configure in InForm Publisher. Configure the Argus Safety only attributes in the InForm Publisher configuration file, as described in the InForm Publisher 2.1.1 Installation Guide.
If an instance of a related form has a start date within the specified range of the AE onset date, the safety event data from the related form is transmitted to Argus Safety with the AE data. For example, if the AE Start Date is March 1, 2018 and the timeframe for collecting related adverse events is 14 days, an AE that occurred on Feb 25, 2018 would be sent to Argus Safety.
Note: If you map the Safety Case-related AE Sequence Number Control to an item in a repeating itemset, the timeframe for related AEs will not be used.
