Step 3: Define sets of drop-down list options, radio buttons, or checkboxes
- At the bottom of the Project Explorer, click the Codelists (
) button. - In the Project Explorer, expand the Codelists folder, and select the codelist you created in Step 1.
- At the top of the page, select the Subsets tab.
- Do one of the following:
- To copy an existing subset, in the top half of the page, select the subset, and click Replicate.
- To create a new subset:
- In the top half of the page, click in the last row.
- Enter a description for the subset, and press Enter or Tab to save the changes.
- Highlight the row.
- At the bottom right, click Add.
- Select the codelist items to add to the subset, and click OK.
- On the bottom right of the page, use the Move Up and Move Down buttons to configure the order of the codelist items in the subset.
