Step 4: Require an item to use assigned codelists and subsets (Optional)
- At the bottom of the Project Explorer, click the Items (
) button, and expand the InForm Items folder. - In the Project Explorer, select an item that has a codelist with assigned subsets.
- Click the Properties tab, which appears on the right of the page by default.
Tip: If you don't see the Properties tab, at the top left of the page, select View, and make sure Properties is selected. - Set the following to False:
- Change assigned codelist
- Change assigned subset
Tip: You only need to configure these settings one time per item. The settings apply to every instance of the item.
