In this chapter Study administrators Library users Setting your machine for different locales I can't import a project archive I export and re-import the same study CSML I can't create an item from a user-created type I can't mark a project as a template Deployment with an in-place revision change fails I delete a rule I deactivate a rule I disable a rule I can't disable a rule I cut a data-entry rule from a study object, but nothing happened A rule test case fails Validation produces errors and warnings A rule in InForm is deactivated I edit or delete a deployment instance There are blank pages in the PDF file created for my annotated study book |
