What data format can I import into Central Designer?
You can import a file in CSML or ODM format.
- Clinical Study Markup Language (CSML) is an XML-based markup language developed by Oracle for representing and exchanging clinical data definitions created in Central Designer.
- Operational Data Model (ODM) is an XML-based standard developed by the Clinical Data Interchange Standards Consortium (CDISC) for representing and exchanging clinical data.
For example, you can use the CSML option to import an exported Central Designer study into another study.
Note: You cannot import a CSML file into a library if the file contains a study design. A CSML file contains a study design if you exported the CSML from a study. To add study objects that are in a CSML file to a library, import the CSML file into a study, use the Libraries tab to search for the study objects, and then drag them to the library.
