Why would I import or export study data?
Importing and exporting are useful for:
- Working with customer support to analyze problems in a study.
- Moving a study from one server to another.
- Importing study objects into a library or study. For example, if a study contains many study objects that you expect to reuse, you can use the import feature to create the study objects quickly in a library or study. After a study has been imported, you can revise, add, or delete study objects as needed.
- Exporting a study or library to a file, for archiving or for importing back into Central Designer or to an ODM-compliant system.
