In this section Why would I import or export study data? What data format can I import into Central Designer? What conditions must be met before a study object can be imported? What modifications can I make to an imported study? What CMSL data is not exported or imported? What are the requirements for importing ODM metadata? How are ODM objects mapped to Central Designer objects? Can I export a single study object? Can I export and import text? What does a translator do with the exported text strings for translation? What is the format of the translation export and import CSV file? What are the requirements for the translation file? |
