Import custom events that were created in InForm Publisher in a release prior to 6.2
- At the bottom of the Project Explorer, click the Study Information (
) button. - In the Project Explorer in the InForm folder, select Custom Events.
- Click Import, and select the CSML file that contains the custom event.
Tips: - The import file is created by a utility that runs during the InForm 6.2 study migration. It converts existing custom events into CSML for import into Central Designer.
- By default, the CSML file is stored on the InForm application server at <Installation_Directory>\InForm\Bin\DBOra\<Study_Name>_CustomEvents.csml.
Your organization might need to move the file to a location that you can access it from.
- The utility only works for active custom events. Inactive custom events are not available for import.
