Create a subject with a status of Enrolled
- Event Name—SubjectEnrollment
- Priority—1
- Prerequisite—None
- Triggers:
- Trigger 1
- Trigger type—Study object trigger type
- Created on the enrollment form
- Event type—Data Value Changed
- Trigger 2
- Created on the item where users enter the date of enrollment
- Event type—Is Not Empty
- Trigger 1
- Results:
Define a result for every item that you want to send to Siebel CTMS, including:
- Result 1
- Result type—Study object status
- Created on the item where users enter the date of enrollment.
- Map to name—EnrollmentDate
- Custom Data section—A name of EnrolledStatus, with a value of Enrolled
- Result 2
- Map to name—EncounterDate
- Result 3
- Map to name— ScheduleDate
- Result 4
- Created on the item where users enter the subject number.
- Map to name—SubjectNumber
- Include Data—Selected
Tip: Selecting Include data ensures that Siebel CTMS is able to process the request without a subject number.
Note: The value is the language independent code in Siebel CTMS for the status Enrolled.
- Result 1
