Initiate an early withdrawal
- EventName—EarlyWithdrawal
- Priority—2
- Prerequisite—None
- Triggers
- Trigger 1
- Trigger type—Study object trigger type
- Created on the item that captures the withdrawal date
- Event type—DataValueChanged
- Trigger 2
- Event type—Is Not Empty
- Trigger 1
- Results
Define a result for every item that you want to send to Siebel CTMS, including:
- Result 1
- Result type—Study object status
- Created on the Subject Number.
- Map to name—SubjectNumber
- Result 2
- Created on the item that captures the date of enrollment
- Map to name—EnrollmentDate
- Result 3
- Map to name—EncounterDate
- Result 4
- Map to name—ScheduleDate
- Result 5
- Map to name—WithdrawnDate
- Result 6
- Created on the item that captures the withdrawal reason
- Map to name—WithdrawnReason
- Result 1
