Map items coded in Argus Safety
If you want the items to be encoded by the coding module of Argus Safety or to be encoded manually by Argus Safety users, you can map the items so that the verbatim data is transmitted to Argus Safety for coding.
- Map the AE_VerbatimTerm data series to the item in which the InForm user enters the AE description.
- Do not map the following data series:
- AE_LowLevelTerm
- AE_PreferredTerm
- AE_MedDRAVersion
- Map the appropriate data series to the item containing the verbatim entered by the InForm user. For example, map the MedicalHistory_Name data series to the item in which the user entered a medical history event.
- Do not map the MedDRA version data series.
When Argus Safety receives the data and creates a case, it attempts to encode the verbatims. If it cannot encode them, a warning appears when the Pending E2B file is accepted, and a user can encode the items manually through the Argus Safety user interface.
