Map to the MedDRA version
Each data series for an item that can be coded has a corresponding data series, called <dsname>MedDRAVersion. <dsname> is the name of the data series to which the MedDRA version applies.
- (Coding data) If the transmitted data is encoded in InForm or in a coding application that is integrated with the InForm, map the <dsname>MedDRAVersion data series to an item that holds the version of the MedDRA dictionary used to encode the transmitted data.
When you map the <dsname>MedDRAVersion data series, you signal Argus Safety that the corresponding data is encoded, and the coding module in Argus Safety does not encode the data.
- (Verbatim data) If you want the coding to take place in Argus Safety, do not map the <dsname>MedDRAVersion data series.
Leaving the <dsname>MedDRAVersion data series unmapped signals Argus Safety that the corresponding data is verbatim and should be encoded in Argus Safety.
