What happens when an instance is deleted?
Descriptions and examples of deleting instances
Description |
Example |
When you delete the Gender item |
No child study objects. Not used by other study objects in the study. |
Item name—PregnancyTest
The instance of the PregnancyTest item is removed from the study. |
No child study objects. Used by one or more study objects in the study. |
A dialog box informs you that the delete will remove all links to the instance. You can continue or cancel. If you continue:
One or more child study objects that are not used by any other study object. Not used by other study objects in the study. |
The instance of the PregnancyTest item is removed from the study. You are asked if you want to include the child study objects in the delete.
One or more child study objects that are used by one or more other study objects. Not used by other study objects in the study. |
The instance of the PregnancyTest item is removed from the study. The codelist on the item is not affected because it is being used by one or more other study objects in the study. |
One or more child study objects that are not used by any other study object. Used by one or more study objects in the study. |
In addition:
