What happens when a link is deleted?
Descriptions and examples of deleting links
Description |
Example |
Results of deleting the item |
Has child study objects or has no child study objects. Is used by multiple study objects. |
Item name—PregnancyTest
When you delete the PregnancyTest item from a form (for example, the Visit2 form):
The PregnancyTest item can be used on other forms. |
Has no child study objects. Is used by a single study object. |
The link to the PregnancyTest item is deleted from the Visit2 form, and the instance of the PregnancyTest item is removed from the study. |
Has one or more child study objects. Is used by a single study object. |
The link to the PregnancyTest item is removed from the Visit2 form. If the codelist on the item is used by only the PregnancyTest item, then you are asked if the child study objects should be included in the delete:
Note: When you delete the final link of a study object, you receive a message that only a single link to the study object exists in the study or library, and you are asked if you want to delete the study object from the study or library after the link is removed. If you click:
- Yes—Both the link to the study object and the study object itself are deleted from the study or library.
- No—The link to the study object is removed from the study or library, but the study object remains in the study or library.
