Library Objects Modified in the Study report
Level at which the report runs
The report runs at the study level.
Description
The report lists study objects (when they exist) that were copied from a library to the study and then modified and saved in the study. For a copied study object to appear in the report, it must be saved before it was modified. Similarly, if you copy the study object, modify it without saving it, and then save it, the study object does not appear in the report.
Purpose
If all study objects in the library have been fully tested, use the report to identify study objects that might require further testing as part of the test plan.
Additionally, you can use the report to monitor whether designers are adhering to library standards for a particular study.
Fields
Fields in the Library Objects Modified in the Study report
Field |
Description |
Study Object Title |
Title of the study object in the study. |
Study Object RefName |
RefName of the study object in the study. |
Library Object Title |
Title of the study object in the library. |
Library Object RefName |
RefName of the study object in the library. |
