Library Objects Modified in the Library report
Level at which the report runs
The report runs at the study level.
Description
The report lists study objects (when they exist) that were copied from a library to the study and then modified and saved in the library.
Purpose
Use the report to identify the study objects that were modified in the library after being copied to a study, so you can determine if an update to the study object in the study is required, as well.
Fields
Fields in the Library Objects Modified in the Library report
Field |
Description |
Study Object Title |
Title of the study object in the study. |
Study Object RefName |
RefName of the study object in the study. |
Library Object Title |
Title of the study object in the library. |
Library Object RefName |
RefName of the study object in the library. |
Note: It is possible for a study object to appear in the report if it has not been modified and saved in the study. For example, if a study object is linked in multiple libraries, copied to a study, and subsequently modified and saved in one of the libraries, the study object appears in the report.
