Number of Studies Containing Library Objects report
Level at which the report runs
The report runs at the library level.
Description
The report lists:
- Study objects (when they exist) that were created in the library and copied into a study.
- The number of studies to which each study object was copied.
Note: Study objects that are marked as templates or types do not appear in the report.
Purpose
Use the report to determine the number of studies to which a study object has been copied from the library.
Fields
Fields in the Number of Studies Containing Library Objects report
Field |
Description |
Library Object Title |
Title of the study object in the library. |
Library Object RefName |
RefName of the study object in the library. |
Number of Studies |
Number of studies in which the study object is used. Note: A study object copied into a single library two or more times is counted only once. |
