Library Objects Modified in Studies report
Level at which the report runs
The report runs at the library level.
Description
The report lists:
- Study objects (when they exist) that were created in the library and copied into a study.
- The study to which each study object was copied.
Note: Study objects that are marked as templates or types do not appear in the report.
Purpose
Use the report to identify how frequently a study object was modified after it was copied from a library to a study. Many updates to a study object might indicate that the study object needs to be updated in the library.
Fields
Fields in the Library Objects Modified in Studies report
Field |
Description |
Library Object Title |
Title of the study object in the library. |
Library Object RefName |
RefName of the study object in the library. |
Study Copied To |
Name of the study to which the study object was copied. A study object has a row for each study to which it is copied. |
