How is Partial SDV set in Central Designer?
In Central Designer 6.3.1, the default values for SVFirstNSubjects and SVAutoSelectRate have been updated to match the corresponding values in InForm, and now accurately represent 100% SDV.
- SVFirstNSubject = 0
- SVAutoSelectRate = 100
- SVDefaultInclude = Include
When you deploy, the Site values in InForm will not necessarily be changed as a result of the deployment. The site values are only updated if they match the current default values.
- If all Site Values match the Default Values, the Site Values will be changed to the new Default Values that were included in the deployment from Central Designer.
For example, if you have a new study, and never modified the Site Values (and therefore they still exist as SVFirstNSubject = 0 and SVAutoSelectRate = 100), they will be populated with the new Default Values from Central Designer.
- If any of the Site Values do not match the Default Values, the Site Values will remain as is.
For example, if you have an ongoing study, and changed the Site Values to be SVFirstNSubject = 5 and SVAutoSelectRate = 50, they will remain this way regardless of the new Default Values that are coming from Central Designer.
