How are Partial SDV default values affected by a migration or upgrade?
Central Designer is designed so that the behavior defined for Partial SDV does not change when you migrate or upgrade from a version of Central Designer prior to version 6.3. In Central Designer 6.3.x, you now have the ability to update Partial SDV settings for InForm sites globally within Central Designer.
- In versions of InForm prior to version 6.3, there was only one value stored for each of the following settings for a site, and they could only be edited in the InForm user interface on a site-by-site basis. These are now known as Site Values.
- SVFirstNSubject
- SVAutoSelectRate
- When you migrate to InForm 6.3.x, two new values plus a new parameter are added to the database for these settings. These new settings are collectively known as the Default Values.
- SVFirstNSubject = 0
- SVAutoSelectRate = 100
- SVDefaultInclude = Include
Because this setting is new in InForm 6.3.x, the Site Value is automatically populated with Include, which matches the actual behavior prior to InForm 6.3. As a result, the behavior will not change.
