Workflow Rules and Global Conditions Report
The Workflow Rules and Global Conditions Report runs at the study level and outputs all active and inactive rules from the study design as a CSV file.
Fields in the Workflow Rules and Global Conditions Report
Fields |
Description |
Status |
Icon that indicates the status of the report:
Error Message(s) |
Description of the error(s) encountered while gathering data for rule action information. |
Rule Name |
Name of the workflow rule or global condition. |
Rule Status |
Status of the workflow rule or global condition; either Enabled or Disabled. |
Rule Type |
Type of rule; either WorkflowRule or GlobalCondition. |
Rule Description |
Description for the workflow rule or global condition. |
Rule Switch |
Expression for the workflow rule or global condition. |
Rule Match
Shows the information about which value selection in InForm will produce the result. For example, if Gender = female, a dynamic pregnancy form would open and this field shows that “female” is the match that will produce the result. |
Dynamic Type |
Visit, form, or form and visit. |
Target Visit RefName |
RefName of the visit in which the item that is the target of the rule action exists. |
Target Form RefName |
RefName of the form on which the item that is the target of the rule action exists. Note: If the item is used on multiple forms in the study, the forms are listed and separated by semicolons. |
Workflow Owner |
Where the workflow rule or global condition resides in the study design. |
Workflow Owner Type |
Object type of the workflow owner object. |
)—Indicates the report ran successfully.
