Studies Containing Selected Library Object report
Level at which the report runs
The report runs in a library only for study elements, study events, forms, sections, items, codelists, codelist items, mappings, data sets, and data series.
Description
The report lists the studies to which the study object has been copied from a library.
Note: Study objects that are marked as templates or types do not appear in the report.
Purpose
Use the report to identify the number of studies to which a study object has been copied. The usage of a study object might influence a decision to maintain a study object or remove it from the library.
Additionally, when you are considering changing a study object and propagating the change to the studies in which the study object is used, the report can help you determine the impact of the change.
Fields
Fields in the Studies Containing Selected Library Object report
Field |
Description |
Study Title |
Title of the study to which the selected study object was copied. |
